3 blade vs. 4 bladed prop
10
2 25 Roosevenlt Lake
I have an 8 horsepower outboard. I understand that when it comes to powerboats, a three bladed prop moves a boat faster at WOT. My question is: given that i have a displacement hull sailboat and plaining is not an issue for me. Is there an advantage to have a 4 bladed prop? Will it give you more noticeable thrust when pushing through chop? will it noticeably affect gas mileage either positive or negative, if so how much? I assume that it will give more thrust at slow speeds and therefore more control at slow speed, or does it not make a big enough diffrence to bother? I would like to hear from someone who has experience with 4 blades vs. 3.
Thanks much,
Dave
BobM
Jun 10, 2004
3,269
S2 9.2A Winthrop, MA
Sounds like this might work for you. I was looking into them for my 8hp, but bought another boat. For the money, which is $90, it looks like it is an equivalent cost and claims to increase thrust and provide better fuel consumption. Can't beat that. Has anyone tried one? Other than that, a 4 bladed prop or a prop with a different pitch would likely provide more torque, which would likely be more helpful. However, it would also result in more drag. That isn't a problem if you have an articulating mount and can get the motor out of the water, but I always noticed a huge difference in boat speed when I lifted my motor up in light air.
http://shop.s2owners.com/detail.htm?fno=240&group=294
Oct 22, 2008
3,502
- Telstar 28 Buzzards Bay
I've got one that I have to mount on my boat. I hope to have it mounted sometime this summer, but it is pretty low on the list of priorities. :)
The drag issue isn't one that worries me, since my outboard mounting system lifts it clear of the water completely when not in use.
