Dan Marques
Apparently the end is near, because my "it will run forever" 1971 British Seagull has gone to that great big transom in the sky.I need to replace it, and having a limited budget, and there being no used long shafts for sale around here, it seems like I have only a couple of options.So, please, if anyone has any comments on any of these, let me know.a) the tohatsu / nissan / mercury 3.5 hp long shaft: does this have enough power / thrust to manuever around the harbor, or get me home if i need it?b) an electric trolling motor: same question as about, also, how much thrust would i need? how to i set up the batteries? how long will they hold a charge? how long can the engine run off a full battery (lugging a heavy battery back and forth daily holds on appeal)c) short shaft: can I use a short shaft from the engine well, or does it have to be on one of those brackets? how hard is it to install a bracket, can it be done while the boat is in the water?Thanks a lot.Dan
