Jim Logan
I've got 30wt. motor oil in the transmission of my 1980 2QM15. Now that I've bought a Yanmar manual (listened to the boatyard operator before - should have known that was a mistake)I find that I should have automatic transmission fluid. I've used it for two years, no problems - I plan on changing to ATF by just removing 30 wt. and putting in proper amount of ATF - Does anyone think this will cause problems? I'm assuming the small amounts of 30wt. left in transmission will mix ok with the new ATF. Anyone got any thoughts on this?
