2nd reef points
173
Oday 25 Tampa Bay
Would someone explain how to use a 2nd set of reef points? I have a single line reef that I love. I loosen the main, tighten the reef line, done! If you have two reef points would you have a 2nd reefing line or rethread the first line? Just how does it work? Thanks, Jack
RichH
Feb 14, 2005
4,773
Usually .....
..... you have a second/separate line for the second, etc. reef. When you need the second reef its usually best to use a 'jiffy' set-up instead of a single line reefing system ... so that you can vary the amount of outhaul tension on the second reef; the outhaul control needed for the amount of how much draft in the sail that you want/need. Single line reefing doesnt allow much 'draft' control.
Brian
Jiffy Reefing
Is usually for the 1st reef, which can be done with boom hanging out. 2nd reef is usually done with short ropes manually, with boom over cockpit so it can be reached. If it is windy I generaly double reef at landing, then if it's not too windy I untie out to 1st reef which is also tied in. I don't worry much about draft if I think I need double reef. Regards, Brian
Jan 2, 2005
779
Hunter 35.5 Legend Lake Travis-Austin,TX
Jack???
once again, WHAT BOAT are we talking about? A little more info. up front will get you a LOT more info. on the back side. My 35.5 Hunter has "single line" reefing for both reef points.
NYSail
Jan 6, 2006
3,178
Beneteau 423 Mt. Sinai, NY
Honeyman
I forgot, but what type boat and mast do you have again. I have a Pearson with an Isomast. Do you have a single line for each reef point or just one line that attaches to both points... Thanks!
