2nd Reef
Roger is correct. You would only need the second reef point if you were off shore and had a long way to go. The proper sequence for shortening sail area is; reef the main, change to a smaller head sail, put in the second reef, change to a storm jib, drop the main and hoist a storm trisail (if so rigged), heave to! If you are still over powered with a reef in, and a smaller jib, start easing the main to depower.Good luck.Michael
