I found that my Yanmar 2gmf diesel engine developed an oil leak from under the tie down stud/nut on the front right side of the facing fuel pump ( straight up from the main crank shaft pulley).Looking at the maintenance manual there doesn't appear to be a gasket at the point where the fuel pump attaches to the block. Just a "shim". Has any one else experienced this leak point and what was the cause or exent of the repair? Just prior to noticing this leak I found that I didn' have the power that I'd normall feel at 2000 rpm. My props are a little encrusted(was planning to go over the side to scrape 'em) but I was baby-ing the throttle level not to over load or cause too much vibration. ThanksJim
