Jim McCue
90degree heat, hot, sweaty and tired from reloading all the boats stuff, I kinda screwed up - connected {backwards!} the main battery in the dark recess under the sink and then put a wonder bar between the block and the altenator to pull out the alternator and tighten the belt.As I started to lever the alternator I saw/heard a small pooff & spark and slight puff of smoke on the back side of the 2GMF. Oddly the Guest 2 battery switch was in OFF position which made me check the main battery again to now see my "backwards" connection. I corrected the wiring and was able to kick over the engine. Problem is my volt meter add-on under the chart table control panel tells me it is at 12v not the usual 13.5-13.75. Also the starter alarm wistle is on continuously but fads in and out abit when I toggle the test switch on the control panel. Could be a bad toggle switch too. I suspect I'm not charging but runnin on the battery.Question: Is the alternator/regulator electronic integrated or modular replaceable on these units? Can I buy a voltage regulator separately or am I in for a new or rebuilt alternator? Is there a fuse of some sort on the back of the alternator that went? ; {Has anybody had this scenario and what was their remedy (and approx. cost)?Thanks in advance.
