2gm20f
Apr 29, 2012
224
Beneteau 35s5 bristol ri
I have a noise coming from the fresh water circulator pump. Has anyone had this happen? I wonder how difficult it would be to replace. The belt is a little loose so I will try to adjust it and see if the noise goes away. Any suggestions would be greatly appreciated.
Thanks!
Thetone
Jan 4, 2006
7,424
Haven't seen (or heard) a problem with 2,000+ hours.
Replacement is easy ................ paying for it, not so much.
Time to open it up and see what's going on inside with one or more broken vanes being the likely culprit.
Hunter 34 Alameda CA
See if the pulley wiggles. Mine failed at the most inopertune time catastrophically. There were ball bearings all over under the engine. It's an easy diy repair. If it's noisy, it's probably going to blow.
NYSail
Jan 6, 2006
3,155
Beneteau 423 Mt. Sinai, NY
Mine went two hours outside of Newport 2 years ago..... had to sail up into harbor and pick up mooring. easy to change. If you start hearing noises it could be time. Loosen the belt and see if you can wiggle pully like was said. You may also see it wobbling when engine is running. I didn't have to replace the whole pump, just the inner part. Housing was fine.
Good luck
Apr 29, 2012
224
Thanks for your reply! Do you know the part numbers of what you replaced?
thetone
