I would like to install both an oil pressure and temp gauges. I also want to keep the existing idiot lights and horns. I have been told that I would have to tap the existing holes for standard sizes and also add T's. Is this true? I really don't want to tap anything on the block.
Does Yanmar or anyone make a T that will fit the original metric holes, senders and new standard senders?
Also does anyone know the size and thread of the existing temp and oil pressure sending units?
The space between the oil sending unit and the main pulley is tight when you add a pressure gauge sender, if I add a T I don't think it will work.
I welcome any options that you might have.
Also if anyone has a photo of their jobs it would be greatly appreciated.
