2gm20f hunter 29.5 trans oil
53
hunter 29.5 napa ca
Sucked the oil out of the trans only got about a pint .Any body know how much the trans holds full ??
Hunter 29.5 1994 2gm20f engine
Jan 4, 2006
7,870
Exactly Enough .............................
........................... to bring it up to the full mark with the dip stick NOT screwed in. No more, no less.
Sounds like you got a little extra for your money.
It's about 0.3 L (0.63 US pint).
1,450
Very important not to overfill ! Because of the quantity of oil appearing on the shiny dip stick it is sometimes hard to see if there is any oil on it. So, I clean and dry the stick, then put a wrap of blue or green masking tape right at the line on the stick. When you dip it and remove, any oil will be easily seen and if any touches the masking tape then you have an overfill situation. DO NOT FORGET to remove the tape and clean the stick before re-installing.
May 24, 2004
470
Hunter 33.5 Portsmouth, RI
From the Service Manual, it translates to o.25 Quarts in the transmission for the 2GM20F engine.
May 27, 2012
1,152
Oday 222 Beaver Lake, Arkansas
Less is more? Overfilling an engine or gearbox can cause the oil to contact the rotating internal parts and be whipped so violently it causes the oil to foam. Foamy oil doesnt offer nearly the lubrication and cooling properties the oil would have otherwise. Kind of along the lines of killing with kindness.
Dec 10, 2003
160
Hunter 30_88-94 Edmonds, WA
The service manual says to use the same lubricant as for the engine. Most people use SAE 30. .30 liters, or 10 oz. US.
