2GM20F - COG V BELT #
50
Hunter 31- Deale
I saw where they recommend use of a cog v belt for Yanmar engines as a replacement. Does anyone have a make/model # for a cog belt for a Yanmar 2GM20F. Thanks in Advance Granfallon (Hunter 310)
Jun 13, 2005
559
Irwin Barefoot 37 CC Sloop Port Orchard WA
Just take your old belt to an auto parts store
Tell them what you want and they'll get it for you. Joe S
Nov 28, 2004
209
Hunter 310 San Pedro
Yanmar v-belts
I also own a 310 Hunter with a 2GM20F. Replaced both belts last year, primary with a cog belt. My best advice is to have the old belts measured and/or with you when you buy and make sure your getting metric rather than english belts, the width to depth are different and important. Additionally, before removeing your belts check the fit on the pullies, they should fill the groove and be flush with the edge of the pulley.
RichH
Feb 14, 2005
4,773
Yanmar belts .....
The sheeves on a Yanmar are pressed mild steel that are VERY subject to rust formation and roughening of the sheeve faces. If you are having 'problems' keeping a belt tight or are wearing out belts relatively quickly on a Yanmar .... pull the sheeves and have them 'dressed' back to smoothe or simply replace them. Yanmar sheeves dont stay smooth very long, and the pitted roughened Vee surfaces are 'hell' on belts. :)
K
Ken
Cog belt? what's that ?
My belt is original. Taper and smooth. SO what is Cog Belt and why is it better to the stock ones from Yanmar ?
K
Ken
Ok found out
what cog belt is. Its a v-belt with teeth like stub on inner side for gripping the pulley.
Dec 1, 1999
2,391
Hunter 28.5 Chesapeake Bay
Belts...
A few years ago, I routtinely replaced both my Yanmar 2GM20F alternator and water pump belts with Yanmar belts thinking they would be the "best" for this engine. After only a few hours use, I just happened to notice that the Yanmar water pump belt had a cut in it and probably would not last through another hour of use. The pulleys were not the culprit here. A poorly made belt was. I heeded the recommendation of a poster on the Hunter 28.5 site to switch to Gates Belts. While a bit more expensive, you can see immediately that they are far superior products to the one's Yanmar sells.
Jun 1, 2005
772
Pearson 303 Robinhood, ME
Now you tell me...
I just replaced mine with Yanmar belts... another thing to worry about now!
