28.5 Shaft Removal
Jun 24, 2004
11
Hunter 28.5 Annapolis, MD
While trying to replace the bellows on my my PSS system I noticed a plastic retention collar had a crack. This is not a PYI but the collar held the rotor in place. It more or less fell apart in my hands. The shaft log was also bad as it was decaying and parts turned into what looked like clay. Both need to be replaced. However, the shaft is not coming off of the coupling after much labor using the compression method. Easier just to cut the shaft. Has anyone removed/installed the shaft while not having to drop the rudder or strut? I intend to remove the cutlass bearing to give a little more wiggle room but wanted the experts opinion. The shaft log is off as well so that's even more play. I've heard from a few on the 28.5 facebook page but wanted to put this out here as well. Thanks!
jtm
Jun 14, 2004
314
Hunter 28.5 Dataw Island, SC
I’m late to your post but I borrowed a prop knocker - an offset “Y” An anvil head on the forward side and the Y tucks forward of the prop. The anvil Head took the whack to back out the shaft.
Also you could remove the 4 bolts on the shaft strut from the packing area inside to get more removal room
You prolly want to do it anyway to inspect those bolts especially if there’s a rust tail around the 4 on the top side of the strut. Crevice corrosion will eat away the middle of the bolt shafts.. I did a post on my experience with pictures of the half eaten bolt shafts!
