28.5 front hatch leak
C
Craig Shaw
The front hatch on my 1985 28.5 needs a new seal the hatch is made by Gray Industries in Tampa Fla. are they still in busness?can I get just the seal or do I need to replace the hatch. If I replace the hatch who makes a good one? Thanks Craig
Jeff D
Replace it
Just go ahead and replace it. It is an all plastic hatch which is probably at the end of its useful life. The cut out size should be 20x20 in.. Don't expect a close tolerance there. Pretty crudely sized at manufature. Look at catalogues to see how much you want to spend.
S. Sauer
Replace with Bomar Hatch
Check out West Marine Bomar low profile 20-1/4"x20-1/4" mode l117871 in aluminum. Carefully break the old sealant with a putty knife, & clean up the opening with acetone. Fill the old screw holes with Marinetex and carefully pre-drill for new fastener locations. Use an electric sander on the vertical edge of the deck to true-up or enlarge the opening if necessary, and seal deck edge with west system if the plywood is showing or the gel coat has delaminated from the plywood. Cure as needed. Install with two liberal strips of Life Seal Sealant on the deck surface (verify Bomar instructions for compatibility). Install screws loosely until sealant oozes out uniformly at flange but don't tighten down and squeeze out all the sealant. Clean up the extra sealant as you go and final tighten the screws in several hours. Seal between the inside flange and the edge of the liner with the same sealant from the inside. Cleaning your hands several times helps keep the sealant off everything else. Good Luck.
