272 whisker pole
45
The snap end hooks to the job sheet and the hook end to the mast? Tried it last night hook fitted but didn't seem secure to the mast as well as I would have liked.
Jun 9, 2008
1,850
- -- -Bayfield
Most whisker poles have an opening jaw on one end (and perhaps another on the other), but sometimes something that looks like a finger with a little hook to it, like you bent only the last nuckle on your finger (bending the part of the finger with the nail on it). The jaw end fits into the ring on your mast and you ALWAYS want to have the jaw opening facing up. The pointed end fits into the cringle on the sail end, or, some pointed ends also have a small sheave where you would then just lie the pointed flat end over the sheet near the clew of the sail and the line would roll on the sheave too.
Pat
Jun 7, 2004
1,250
On the original 272 the Z-spar mast had a tract on the forward surface to which a sliding connection piece (ring) connected (assumed also supplied by Z-spar). This type of connection allowed the whisker pole connection point to slide up and down, i.e. be infinitely adjustable. Mine was lost overboard and I never saw another one on any of the 272's that showed up at our club....I'm going to try and go to the lake today and I will look at the other
272's and see if they still have the ring. Z-spar may still have some available.
Your mast brand may be different and the ring connection may be as well.
The other emails below note the correct use of the pole.
Jan 10, 2012
45
It is a z spar and has fixed loop on front of mast and the non clip in does look like a bent finger. Thanks for the help!
