I just purchased a 272 Steering Conversion Kit from a long-retired Oday dealer who used to sell a complete, original, Edson steering kit for the Oday 272. He sold them to buyers who wished to change from tiller to wheel on their 272s.
To my surprise, I find it is the original RLA (remote linear actuator) designed by Edson for the Oday 272.
I got the kit, which includes the pedestal and shift lever ring, and a 28" Destroyer wheel for slightly more than the price of the Destroyer wheel at today's prices. Mind you, he had this kit left over from the 1980's when he was a dealer. It is an antique, in original packaging and wrapping!
Anyway, my only worry is that my outboard motor mount will interfere with the actuator arm. I have to move my mount lower in the offseason anyway because the new Garelick mount doesn't put my Yamaha 9.9 longshaft low enough for my liking, just a little above the planing fin (?). I read the instructions for the installation, and the actuator arm needs to meet the leading edge of the rudder 1/2 way between the pintels. I hope the mount will be low enough to allow the arm to fit above it. To my advantage, I already use a remote throttle, so I don't have to worry how low the mount goes in relation to controlling the motor. I will probably convert the motor to use the pedestal throttle and shift controls. I could imagine having to fabricate a deeper mount to allow the motor to not interfere with the actuator arm in either the raised or lowered position.
So, has anyone experience with this combination: outboard with RLA (272 LE steering) ? If so, what wisdom would you pass along? If you did the installation yourself, what did you learn? What would you have done differently?
Thanks,
Andrew.
I'll post pictures when I do it, but it may be an offseason task, as the boat is at the dock now, and I would rather sail her now!
Thanks,
Andrew.
