272 extra forestay?
Dennis
My 272 has some kind of eye installed on the front of the mast at the level of the spreaders, and also a kind of inverted U-bolt on the foredeck. I have seen these on other, and especially bigger, boats -- for instance on a Beneteau 42, where they are used to install a second forestay and, in the case of the Beneteau, a furled storm sail. Has any 272 owner had experience of this? If so, is it worth installing a second stay, or is it better to clear the deck of a hazard that one will never use (after all the furling genoa can be reefed).
bruce cornell
inner stay
perhaps you might think about the storm sail idea, i don't think you would want to use a part furled gen as a storm sail, in a REAL storm. and, you have a place to attach jack lines.
V
Vic "Seven"
Sounds like what I am going to have to do to ...
add places for blocks to control a lift and downhaul for a spinnaker pole. Vic "Seven"
Dennis
Thanks
Thank you for the comments. After further thought, and since I am day sailing and only occasionally coastal cruising, I shall remove the deck hazard (it is easy to take a step backwards and trip on it). If I installed a second stay I can imagine problems with the genoa when going about (suppose it got backed on the wrong side of the small stay, for instance). It seems nobody who read this post actually has used a second stay. I'll wait a few more days though, just in case.
