27' Main Sheet Blocks
Mike
I need to replace my standing blocks for the main sheet lines. Does anyone know where I can order a replacement? The double block on the starboard side of the boat is in the worst shape. The fiberglass block wheels are breaking apart.I have not had any luck finding a similar replacement from West Marine or any of our local marine stores.
A
Andy
Your chance to help two sailors
I need these blocks also. Andy "Baroque"
Dan
you can have mine
i replaced those blocks with a traveler. the blocks are OK but i hated not having a traveler. you can have them if you want them. email me at upwindan@intergate.com
May 25, 2004
32
Hunter 27_75-84 Lexington, NC
I replaced the sheaves in mine.....
I found some the measured close, drilled out the rivets in the block, got some SS Shoulder Bolts & SS Washers & SS Nylock Nuts from McMaster Carr, and bolted it back together. Much, much cheaper than new blocks (unless, of course, somebody gives you their old ones!).
