H
Hart Jacobsen
I have a 1996 MacGregor 26x and have noticed that I am unable to adjust the centerboard up or down when there is any sideward pressure when sailing up wind. When I inspected the pivot pin and the hole through the centerboard I found the hole quite a bit larger. The pivot pin is 1/2 inch and the hole is 5/8 inch. This slop in the size of the hole would allow the centerboard to jam against the side of the centerboard trunk and not allow any adjustment unless there were no sideward pressure. The centerboard adjusts very easily when you are dead into the wind. Does anyone know if this is a normal design feature of the centerboard and thus takes the stress off the hanger bracket and pivot pin or is the hole worn too large and I could correct this by putting in a bushing?
