Bernie
A couple of years ago, I took some pictures of a 260 being built at Hunter's Florida factory. I posted them on the photo forum at the time, but for some reason those photos are no longer viewable on the forum. Several 260 owners have emailed me and asked me to provide the ballast tank pictures again. I have finally found my original photos and reposted them along with a couple of others I had not previously posted.One question about the water ballast tank (I keep my boat in a slip year-round for the most part). I often notice some water filling the depressed area around the vent plug. If I remove the plug, at least a gallon of ballast water will gush out and then stop. I usually then remove a few gallons more from the ballast tank with some tubing and a 12v pump, but the small void I create under the vent opening usually disappears within a few weeks and the vent starts slowly weeping water again. Are any of you 260 owners that keep your boats in the water having a similar experience? I know I could tighten the vent plug more but I worry that might overpressure the tank seeing how fast the water gushes out initially when I remove the plug. Bernie
