Captain Ron,
I know it's an M25XP, and, as such, should have the simpler wiring. But I wrote this for a constantly recurring issue with newer engines where the "improved" (HA!) wiring had the glow plugs and oil pressure tied into running the fuel pump at startup. If you have the simpler straightforward wiring, forget this, but it's the only other thing I can think of. Good luck. Can't wait to hear. (There is fuel in the tank right?
The newer Catalina and other brand engines have a dual start wiring arrangement where the pump comes on when the glow plugs are energized and then stops until the engine starts AND only resumes when the oil pressure is made. I find this kinda dumb for bleeding, but the engines are supposed to be "self-bleeding." But, "Self-bleeding" works for the primary filter, but doesn't always work on that secondary filter, which is why it makes me think the concept is dumb. There's another downside to this silly design:
...requiring holding the glow plugs via the keyswitch spring position ON while hitting the start button MEANS that there is a continuous draw on the battery bank from BOTH the glow plugs AND the starter motor. Our C34-group experience is that this INHERENTLY leads to tough & rough starting. The Mark I “trick” has always been to RELEASE the glow plug (button in our Mark I case) BEFORE the start button, so that both heavy amperage draws are NOT on at the same time.
and
Another interesting sidebar to this whole "when does the fuel pump run?" issue just occurred to me after stumbling over this thread:
http://c34.org/bbs/index.php?topic=64.0 or any other of the many fuel bleeding posts.
IF the fuel pump ONLY works when the glow plugs are held on with the spring switch OR when the engine is running, bleeding the fuel system is a real PITA. To successfully bleed the system, as discussed here and finally summarized by Ken Heyman (
http://c34.org/bbs/index.php?topic=2884.0), it's MUCH easier to run the fuel pump without the engine on, and why would you want to have to energize the glow plugs when you bleed the engine?
Another one of those
UNFORESEEN CIRCUMSTANCES and
unintended consequences as a result of a "design improvement" that makes things worse, not better.
and:
http://c34.org/bbs/index.php/topic,3347.msg21275.html#msg21275
Of course, I'm not opinionated about this at all!
In that case, I recommended to our skippers that they re-wire the stupidity out of their systems and just run the pumps all the time.
Here's a perfect example:
http://c34.org/bbs/index.php/topic,5078.30.html
Good luck. You'll love that pump when ya need it!
