how many people will you have with you?
Hello,The forecast is for a lot of wind. Should you go out? I don't know.How many people will be on the boat with you? If you have a few people,and they are either experienced sailors, or don't get scared easily, that would be a big help. Also, how will the waves be? IMHO, waves areworse than just wind. I would rather have 25 kt winds and small wavesthan 15 kt wind and 5' chop. I sail on the Long Island Sound, and ifyou get a stiff westerly wind against an incoming tide, the waves becomenasty. When the tide turns around, the waves die down and sailing is fun.Also, as previously mentioned, what is your sail plan? If you have a 100% jib and a main with a big reef (or two reefs) that would be betterthan if you have an old 150% genoa on roller furler.Lastly, how is your motor? Will you be able to motor into that windand seas? If not, then I don't think going out would be a good idea.Good luck and let us know what happens.The forecast here is for lots of rain and winds gusting up to 50 kts.I am staying home!!!Barry
