I'm trying to understand the plumbing inside the '84 25.5 of mine.
The documents I have found here show a very crude, single-line diagram.
So yesterday I visited her (in cradle) and see that the galley sink drain goes straight down into the cabin sole - there is a shut-off valve. Where does that drain exit? Out the starboard side?
Also, in the floor, about mid ship, a large section of flooring lifts up and you see where the keel bolts attach. In that space (which is clean as new) there is a plastic hose - maybe 1/2" ID, what's that doing? should a bilge pump be attached to it?
Are there better plumbing documents out there?
thanks
thanks
