25.5 Hunter Oil Leak
Hunter 25.5 Richmond VA
Have a 1985 25.5 Hunter with a 1GM10 Yanmar. It was laid up since 1998 but resurrected it last summer and brought it down from Cheasapeake Bay to Wrightsville Beach NC (300 miles) last summer. Just started the diesel but found a significant oil leak, however can,t see the source.. I did chance oil and FILTER, I hope its the filter, so thought I'd ask if anyone can tell me a compatible filter No. for a common manufacturer. Hope that's the problem, if not any thoughts on the source before I start tearing thinsg out.
Also, has anyone made a template to replace the flooring.
Also thanks to the guy (forgot his name) that pointed me to where to get specs for a gooseneck fitting that was stolen while she was laid up.
Thanks, Kerry Owens
Just Goggled 1GM10 oil leak and found that this is common problem with many suggested repairs so responses not urgent but welcomed if effective Thanks. still would like a template for replacing cabin sole Thanks Kerry Owens
Nov 6, 2006
10,251
Filter interchange is Fram 3593A or NAPA 1568,or AC DELCO PF 1127
