I'm interested in buying a 240, but it does not have a trailer. The boat will be launched if I buy it, but I am concerned that if I buy a trailer separate from the boat and the boat and trailer don't fit once I try to get the boat onto the trailer at the end of the season (the boat will be on a mooring for the season), then I will have problems I don't want to deal with at a time when there is not a lot of it. Any thoughts?
Thanks,
Mitch
As I remember back in the 1980s while walking in a giant warehouse where the O'Day dealer had these boats in stock, the 240s were sitting on the same type of trailers as the O'Day 222s. These trailers were Load-Rite roller trailers with a two wheel single axle that was set up for the weight of the O'Day 240. I don't remember whether the trailer had keel rollers like mine but I do remember that the 240 had a wing keel.
With that said though, I would buy a tandem bunk trailer that will support the weight of your boat and get the next size up that would fit a longer boat. You may be able to buy about ten 24" adjustable extension brackets to support your bunks. For the trailer's keel support, all you would need is a couple of pressure treated planks sandwich together and clamped to the cross members of your trailer frame. You shouldn't have to drill holes in the cross members for these planks. The reason why I mention a longer trailer is so you won't need an extension tongue for your trailer to float your boat on and off it at the ramp. My boat is an O'Day 222 and it weighs about 2200 lbs. Trinkka 21' 9" long. My trailer is good for a 23' boat and the weight capacity is 4600 lbs.
I would go to a large trailer dealer and tell them what you have. They have all the specs on your boat in their PC. Even if you don't buy off the guy, you'll have a pretty good idea of the carrying capacity needed, the length of the trailer, and the type of extension brackets and lengths. Check through the threads on this site. I posted a lot of pics of my Long Mfg Trailer along with info about the brackets and trailer set up.
Joe
