240 stantion screw not catching
May 13, 2014
2
Hunter 240 Hawk island marina
My stantion on the starboard side is not tightening. It's the top screw and I'm not sure what to do to tighten it. I was thinking of filling the screw hole with wood filler or puddy so it has something to grab
Jan 18, 2013
76
Hunter 340 Bayfield Ontario
I've used that metal putty that comes in two parts, kneed together fill and it can be drilled. You could also get a bigger screw.
Feb 18, 2011
341
Hunter 260 Cave Run Lake, KY
Those bolts screw into a threaded aluminum plate embedded in the fiberglass. Either the hole or bolt is stripped. On my 240 you can access the back of the stanchion through the electric panel (aft stanchion) or the access panel (forward stanchion). You could use a slightly longer bolt with a fender washer and locknut. Or drill out slightly larger and tap threads for a larger bolt.
-na -NA Anywhere USA
As the expert here, follow Cave Run's advice and thank you Cave Run. Filling in the hole will not and again not resolve the issue
May 13, 2014
2
Thanks guys, this site is great for someone like me to get the extra insight I need. I will have many more questions as I continue to fix and upgrade my hunter 240
