Mark Cooper
Since getting my 240 three weeks ago, I've had major difficulties raising the centerboard. From reading a few posts here, I thought this might be normal; then I took the opportunity to investigate everything this weekend. It turns out that the nylon pulley beneath the mast is broken and the pin holding it in place is pulled from its retaining bracket. I'm planning to contact Hunter today to see if it's possible for me to replace this myself (I'm not sure if the screws holding the mast step plate have a backing plate or bolts and there's no access port beneath the mast). My main reason for writing this is to (a) see if anyone else has encountered this (b) see if anyone knows whethere there is a backing plate beneath the mast step and (c) to alert others to the possibility of this defect. The pulley is obviously in a recess beneath the mast on the starboard side of the boat.
