Roller furling
Most of the time, you can obtain a storm jib type sail with the roller furling. Some systems do not allow you to raise the sail off the deck much and as a result, the life line interfers with the jib. I have virtually put CDI or the Flexible furler systems on the 23.5 and 240 with success which will allow me to raise the sail off the deckas well. All the folks that use the CDI system will agree that it does work and in fact , I have furled the jib into a storm sail configuration many times and it works. Based on experiencesince the introduction of the 23.5 on 8/15/92
