222 info
Bob, Years ago when I lost my mast, I had this rigging store get me another Z Spar mast. They seem to have most of the Z Spar mast extrusions and you may be able to recognize the parts on this site if you have Z Spar. My 1986 O'Day 222 came with Z Spar and it has their label on the mast. However, when I replaced my mast, I had this outfit make a few drastic changes to the mast like; a Stainless Steel mast hinge Tabernacle plate, and the Jib Halyard rerouted to exit near the Mainsheet on the mast, instead of a small sheave at the bottom of the mast(internal halyards), a "steaming light" installed about 2/3s of the way up the mast, along with some heavier gauge lower stays. A lot of the mast extrusions for Z Spar were made in France and they weren't the greatest. Especially the hinged mast step which is made of cast aluminum and can break very easy. Anyway, a good rigging outfit can pretty much do anything that needs to be done on a mast, and not necessarily this outfit that I'm giving you the link to. Good luck with that.
