Sailboat trailers
I went througth the trailer search when I got my O'Day 22. We used my brotherinlaws untill I could get my own. There are places out there to get new trailers with bunks, but they are expensive and could cost more than you paid for the boat. I found an older motorboat on a newer trailer. I sold the boat for more than I paid for it and kept the trailer. I took the rollers off and welded vertical tubing in there place. On top of the tubing, I put the bunks. Bunks are about the best system for your boat. they put more support on the bottom of the boat than the rollers do. Now that you own a boat, you are going to have to be real handy and creative. By the way, a single axile trailer with a capacity of about 3000 lb should be enough. The boat is about 2200 lb then add in the motor and gear and you will get up there.Good luck and let me know if I can be of helpKevin
