2019 Season Launch Prep
Slartibartfass
Capri 22 Mod
Dec 13, 2015
499
Catalina Capri 22 1139 Mamaroneck, NY
Epoxied the Transducer yesterday.
Added a small bead of 3M4000 around the top of the rubrail where it touches the hull. Still need to add some on the bottom of rubrail.
Started to fix keel...
After sanding:
TotalBoat 2 part fairing compound:
First coat:
Second coat after some sanding:
Will add a layer of fiberglass over the fairing and then add a few layers of barrier coat....(weather/temperature permitting... right now borderline).
Need to replace deck connector for mast electric (and plug at mast).
Jul 28, 2016
95
476
Wow, what exactly took a bite out of your keel? Did that happen as the result of a grounding, or perhaps a yard or trailer related incident?
You might want to check your keel bolts to make sure they have not loosened.
Slartibartfass
Capri 22 Mod
Dec 13, 2015
499
No all is well. No leaks or stress cracks in the hull... Happened on the last race (pre-start) hit a rock at relatively low speed...
