anyone know the standard equipment ? Steaming/anchor light combo, anchor light needs replacement lamp.
There is an Anchor Light. Also there is a Navigation Light. But the CG does not provide a regulation for a
Steaming/anchor light combo.
Here is the info from Boating Magazine showing the CG requirements for boats and specifically Sail Boats.
The image identifies a boat at anchor has an all round light at the top of the Mast. The Aqua 50 as identified by
@Nodak7 is a light that gives you a 360 degree light out to 2nm.
The Aqua Signal 40 series could also be used. It can be a single white light or you can mount a dual Anchor and tri color Navigational light. This fixture accepts LED light bulbs. That is what I put a top my mast.
The Steaming light being on the front of the mast is located about 1/3 down from the mast head. The requirement is the steaming light provides a 225 degree white beam out to 2 miles. It must be at least 1 Meter above deck lights.
Here is a combo steaming light and a down shining foe deck light. The Aqua Signal Series 25 Classic.
