I have a 2006 Honda 9.9 that I purchased last fall. I started it up to do some spring maintenance and noticed a tiny amount of water spitting out of an empty threaded hole which appears to be on the thermostat housing? near the starter. A marine mechanic says he has never seen a leak there, and that I probably need a new housing.
Can't I just plug the hole using a plastic bolt into the unused threaded hole? What is this hole used for anyway? See picture at its center, the light gray plastic with hole, looks like a bubble on the inside of it.
Thanks for your help.
