2005 Hunter 456 Sailboat Prop. Zinc Size?
Apr 15, 2013
3
Hunter 456 Sarasota
I have a 2005 Hunter 456 Sailboat. My diver can not determine the Prop. Zinc Size & the owners manual does not cover that subject. I know the Shaft Zinc is 1 1/4. Any owners know what size I need for a Prop Zinc?
Prop zinc. Do you know the type of prop you have? Not all props use “prop zinc’s”.
As James has shared, not a need if you put on a Shaft Zinc. Your shaft size will give you the correct diameter.
Feb 26, 2011
1,428
Achilles SD-130 Alameda, CA
A 1 1/4" shaft takes a "D" prop anode
Here's some info for your diver:
3/4" shaft= A
7/8" shaft=B
1" shaft= C
1 1/8" shaft= C
1 1/4" shaft= D
1 3/8" shaft= E
1 1/2" shaft= F
1 3/4" shaft= G
2'" shaft= H
