2005 Hunter 38 red boot stripe
May 22, 2022
11
Hunter 38 Long Pond, Conception Bay
The stripe on my boat is oxidized past redemption. Is this tape or paint, and if the latter, does anyone know the color code? Can I use Interlux Topac Plus?
539
Hunter 380 Comox BC
It was paint on our 380. We just redid ours as well... used TopLac Plus .... were in a rush so we sanded, 2 coats of primer then 3 coats of paint by roller. Ideally it would be sprayed on , but that was just not an option this time in the yard. Looks great. A tiny bit of orange peel once you're up close. To do it again, I'd use a foam roller or spray for a more uniform finish.
May 22, 2022
11
Thanks for the coast to coast response. I'm assuming the roll and tip application method should also improve the finish.
Cheers
