The plastic around my bow roller pin has cracked and the bow roller needs to be replaced. Does anyone know the size of the pin so I can order the correct size bow roller? Thanks.
Check here on the SBO store site. They have listings by model and my have the size info and part you are looking for.
I won’t be at the boat for a few days to measure mine
Are you sure that it is a pin? The 38 was a slight variation of the 376. The 376 has a bolt secured with a nut inside of a metal tube that the roller rides on. The bolt and nut come off easily, the metal tube freezes in the mount and is difficult to remove. West sells a roller that fits on the metal tube.
