H27 (2005)
We have sailed our 2006 H27 for 2 years now. We looked at a 2005 several times before we ordered our boat. I don't really have any knowledge of the 9 HP motor, but I'm guessing it would be fine for lake sailing since you won't have to worry about tidal currents. It would probably be best to make that judgement based on a sea trial. The 14 horse propels the boat at about 5 - 5.5 knots at cruising RPM if you want a point of reference.Both I and the broker we purchased the boat from considered the in-mast furling option to be overkill for a 27-foot boat. We don't find the standard mainsail to be difficult to handle since it came with lazy jacks that catch the sail. It isn't difficult to reef either.The traveller takes up a lot of room in the cockpit. Its primary purpose seems to be skinning and bruising shins. Sail trim seems to be its secondary purpose. Since the boat does have a boom vang, I wouldn't be too worried about it unless you really like to fuss with sail trim in minute detail. You'll probably find the cockpit more enjoyable without it. I doubt we would miss it.The only things I would point out:1. The 2006 and newer boats do have portlights in the hull, which made a big difference in the amount of light down below; they also reduced the "tupperware" feeling you get inside the boat.2. You will want to check the wood structure supporting the aft cabin mattress for mildew - on our boat, the wood structure was raw plywood that I later painted with exterior-grade paint. 3. I would also just watch the cabin roof where the hood slides because it rubs against the gel coat. We eventually will install stainless slides for the hood to slide on. If you're just using this as a big daysailer, you'll probably be happy. But if you plan to spend nights on the boat, you might want the version that has all the cruising kit (electric cooler, butane stove, toilet, etc).
