First time motoring at night, turned on the Steaming light and it lit and so did the Anchor light. That's odd, since the stern light comes on with the Navigation lights only the Masthead light, located a couple of feet over the spreaders, should light to give the 360deg white light for motoring.
Looked at the wiring of the 3 position Anchor/Off/Steaming switch and found a diode connected to the outside light switch tabs that feed the separate Anchor and Steaming lights, thus creating the above lighting. The wiring diagram also showed the diode. Cutting off the diode remedied the incorrect lighting.
The diode is only necessary when the Perko style combination Anchor/Steaming light like shown is used; one bulb is the Steaming light and it is necessary to light the aft bulb, also, to give the 360deg for the Anchor position. It was probably specified originally, but this hull, an early 2005 27-3, has two separate lights for Anchor and Steaming plus the stern mounted Stern light. The wiring diagram for the 240/260 electrical schematic which most likely uses the Perko style light, also shows the diode.
