2004 Hunter 33 - Yanmar Throttle
lbd
Aug 26, 2010
27
Hunter 33 Melbourne Australia
Pedestal mounted throttle on my 2004 Hunter 33 with 30hp Yanmar doesn't appear to have out of gear function. No gearbox disengage button or lever evident. Can anyone advise if this is usual or lever has been modified.
Jun 3, 2004
143
Hunter 33 Santa Barbara
I have a 2004 H33 - and it has a small push button at base of throttle handle. It is black, about 1.5 inch dia. Push it in then move throttle to either forward or reverse to change rpm, while disengaged.
Michael
Dec 19, 2006
5,836
Hunter 36 Punta Gorda
Neutral
Sould be a spot in between that is neutral no forward and no reverse so the boat and prop will not engage and like mentioned push in black button and move lever forward to raise RPM's in neutral.
Nick
Oct 22, 2005
257
Hunter 44DS Redondo Beach, CA
If the above doesn't help, it's possible it fell out. It's a black rubber cover at the base of the throttle with a metal button underneath it. If the black cover comes off, it's possible for the push button to fall off as only the cover holds it in.
I added some silicone adhesive to the rubber cover to hold it on.
Sep 20, 2006
2,955
Hunter 38 Georgian Bay, Ontario, Canada
Possible that is did fall out. Mine was missing when I bought our boat. Ended up buying a whole kit through Hunter dealer and installed button and black rubber cover. I too used a dab of sislicone to hold in place.
