Does my shower drain directly into the main bilge? The shower drain pump (located opposite side of boat from shower) connects to the main bilge so I assume the shower drains is the main bilge and the shower drain pump is also the bilge pump? The shower will not drain so I assume I need to snake it out and expect the snake to come out in the main bilge
where the keel bolts are? The shower/main bilge pump seems to work fine when I fill the bilge with water.
also should I expect the refrigerator to drain directly into the main bilge where the keel bolts are??
