2002 Hunter 326 Davits
Oct 29, 2005
2,366
Hello UN, I too have a 326 but davit is not on my to do list. Sorry no answer there. I noted in your video you've removed the rear berth bulkhead to transom area. Qn: is it easy to take out and put back the bulkhead? How is it removed?
Btw I watched your video on marinizing a portable genset. Interesting. I didn't get what you used to spray on the electrical wiring and components. Thank you for the idea.
KenY
Jul 11, 2016
18
Hunter 326 Oriental, NC
KenY,
The rear bulkhead was pretty easy to remove. There are a couple screws on the starboard side and the board slides up, then into the cabin to be removed.
I used Boeshield on the electrical components. It's a clear coating that will help keep water off the electrical components.
Thanks for checking out the videos.
