2001 Beneteau 331 Oceanis operable windows bug screens
Apr 19, 2021
6
beneteau Oceanis 331 Collins Bay, Lake Huron,
Hi Everyone,
In a new to me Bene as above, there are plastic (PVC) bug screens for operable windows. They are somewhat sophisticated with a lot of items of unknown to me functions and it must have been a nightmare to fabricate. And they do not stay where they are supposed to and it is a miracle that I did not loose any of them. In addition they can be installed only from outside and only when the window is open. Bad design, sorry Beneteau. But I still love the boat though.
I was thinking of fabricating something simple that can be quickly installed from inside and easy removeable. Thought about Velcro, but perhaps small magnets epoxied to the frame (aluminum) may be more elegant solution. I am a fresh water sailor, so carbon steel frame that would stick to the magnets should last if properly coated.
Has anyone come up with any better solution?
Jun 21, 2004
3,213
Beneteau 343 Slidell, LA
I have a set of screens for the Lewmar opening ports, just like yours; however, I have never attempted to install. These are Lewmar ports & screens that were factory installed by Beneteau. Lewmar is generally considered to be a quality supplier of sailboat hardware. On your boat you will find an abundance of Lewmar products. Suggest that you check on Lewmar’s site for instructions / tricks on how to install the screens. You can also check with Hatchmasters.com.
congratulations on acquiring your new boat!:beer:
