2000 Hunter 320 Windlas Switch
stewy
Apr 11, 2013
4
Catalina 31 Little Current
I'm looking at buying a specific 2000 Hunter 320. It seems like an amazing boat. Haven't seen it yet but the ad specifies that the windlass switch needs replacing. Not sure what that means and why it wasn't fixed before. Big job?? Costly job?? What brand of windlass would have been on this model?
Jun 6, 2006
6,990
Most windlass switches are foot switches. you use your toe to control the windlass while you tail the rode with your hands. Getting access to the back of the switch to remove it is needed as it is a weather proof type switch. I'm not thinking this would be a incredibly complicated job but the switch may be a bit pricy.
Also, the switch only controls the high current solenoid that actually supplies current to the windlass so there may be issues with that. If the switch is ok but the solenoid is bad the symptoms are the same.
Course this could be seller code for the windless does not work too. Press the foot switch and nothing may be the switch, may be something much more expensive like the windless itself.
All said, replacing parts is not that bad but you will want to use that as a bargaining chip
Mar 5, 2012
67
hunter 375 Chicago
My 2000 H320 doesn't even have a windlass, let alone an electric one. Did you buy the boat?
Gareth
Oct 29, 2005
2,366
If the 320 is like the 326, replacing the foot switch is easy. You'll need to drop the woodwork (covering the windlass) at forward berth. Everything there is easily accessible.
