how much space do you need under the ring to have the lift mechanism work ? i have a bunch of old bronze pull rings , some are bigger depth than other.s
Are you referring to sailboat ownersask for a flush ring catch on the SBO store. If you go to Google it's kind of like looking for a jib sheet at the rope store they won't have one. ()
I tried. No 2x2 but thank you for your suggestionThought of these guys too
Stainless Steel Marine & Boat Hardware | Fishing Boat Hardware
For over 50 years GEMLUX® Inc. has been delivering world class, highly engineered stainless steel marine hardware, on time, and with a smile.www.gemlux.com
They were friendly and mostly helpful when I was looking for hinges with removable pins to replace the ones on my boat. I found the exact hinges I wanted in their catalog but they were only available to a particular boat manufacturer. They would not tell me who though so there was no way to contact them and buy them from the boat manufacturer. I ended up grinding the heads off of my hinges and buying longer pins that could be pulled off when I wanted to remove the top.
I tried but no luck but sure am learning about slot of supply sites that will be helpful. I live having an old boat in good shape but it isn’t easy to find this part. I may try to fix the one I haveThought of these guys too
I will. Thank youJust a loooonnnggg shot. You might try S2. This pull ring looks like an anchor locker latch or something similar. Looks like my anchor locker..Perhaps they carried it over to the power boat line..
Ron also found some at Bacon Sails in Annapolis for about $14 ish.I think you meant FLUSH ring? Try McMaster Carr, McMaster-Carr for "lifting rings". McMaster-Carr
Hi guys, I'm back on line. That GEM was like the new one Bacons had for 14$. It was AMONG ALOT OF PERKO STUFF. Thanks, Tom.I tried. No 2x2 but thank you for your suggestion
I tried. I think I might have to see if I can makeyes :
Owner resources, parts, accessories, boats for sale, and more.
Owner resources, parts, accessories, boats for sale, and more.sbo.sailboatowners.com
thanks. I’m going to bacons yomorrowRon also found some at Bacon Sails in Annapolis for about $14 ish.
Ron was in the Time Out chair.
