If the HX capacity is adequate the thermostat should regulate the temperature at equilibrium at the set point of the thermostat. Basically it will modulate to control the temp at the desired point. Since mine is going higher it is either insufficient HX cooling capacity or insufficient raw water flow to remove the heat at a fast enough rate. I thought I had pretty good water flow but didn't actually measure it as I was under way. I think the 2" probably does the job when everything is in tip top shape but has no reserve capacity to allow for partial restrictions in water flow, or heat transfer changes due to scaling. Since removing and cleaning the system is a PITA I think it best to put in the upgrade to get a bit of reserve capacity and reduce the frequency of removal and cleaning. I dove on the boat a month ago to clean the hull and the intake seemed clean but critters might be growing inside the strainer. I live in barnacle and oyster heaven so I won't be surprised to see some restriction. Had to leave town for a while, I'll update this thread when I get back and go through the system. Thanks all for the inputs.
For another thought why have the heat exchanger mounted on the engine? Why not have a nice heat exchanger installed where it is easy to service like right next to the water heater in the cockpit locker. It is just a bunch of hoses so it theoretically can be located anywhere and doesn't have to be this Universal style design. I wonder if a water heater would do the job by circulating the raw water through the fresh water circuit and the engine coolant through the system already in use? The water heater is a heat exchanger and might have capacity to cool the engine? You could have a water heater for the fresh water in the boat and a second one for the engine cooling. Maybe a better way to skin the cat?
Maybe Maine Sail can design a new "Universal" remotely located heat exchanger with simple cleanout capability that he can license for production and sell as an aftermarket device and make millions on it? We would all induct him into the SBO hall of fame!! The following is an example (no affiliation with this company, just an example of an alternative possibility):
Brazed-Plate Liquid-to-Liquid Heat Exchangers for Maximum Performance
Lytron’s brazed-plate heat exchangers are unsurpassed for liquid-to-liquid heat transfer. Their innovative design packs maximum performance into a compact and reliable package. The herringbone construction allows for maximum heat transfer making this heat exchanger extremely efficient. The liquid-to-liquid brazed plate heat exchanger is a highly reliable and rugged part with stainless steel sheets brazed together at the edges and at a matrix of contact points. Compatible with a wide range of fluids, we offer copper-brazed for water, EGW, and other common coolants, or nickel-brazed for high purity and other corrosive coolants.
High performance in a small package: Lytron’s liquid-to-liquid heat exchangers are up to 80-90% smaller in volume and weight than a conventional shell-and-tube design. The counterflow design utilizes stainless steel sheets stamped with a herringbone pattern of grooves, stacked in alternating directions to form separate flow channels for the two liquid streams. This allows 90% of the material to be used for heat transfer, making it extremely efficient.
High reliability: The plates are brazed together at the edges and at a matrix of contact points between sheets, ensuring that the heat exchangers are highly reliable and rugged.
Copper-brazed and nickel-brazed versions for compatibility with a wide range of fluids: We offer copper-brazed units for use with water, EGW, and other common coolants. Our nickel-brazed units are appropriate for use with deionized water, high purity, and corrosive fluids.
High operating temperatures and pressures: Copper-brazed units can be operated at temperatures of up to 383°F (195°C) and pressures up to 450 psig (31 bar). Nickel-brazed units can be operated at temperatures of up to 662°F (350°C) and pressures up to 232 psig (16 bar).
Standard heat exchangers can be purchased from
our distributors. Lytron also accepts standard heat exchanger
orders from OEM's for 10 or more heat exchangers and/or for prototyping purposes.
Please review heat exchangers
specifications, options, and ordering information.
Need a
custom heat exchanger? Request a custom
heat exchanger quote today. (Minimum quantities apply.)
