Electrical
First problem is battery charging. 45 minutes of running the engine at 1400 rpm is insufficient to recharge the batteries. What kind of alternator and regulator do you have? If it's an OEM,a standard 55 amp internally regulated, you won't get much out of it.Voltmeter at alternator reads 14v, but voltmeter on control panel reads only 13v. The difference is in the voltage drop in the wiring AND IN THE CONNECTIONS. You should also measure the voltage at the batteries.To charge the batteries does the circuit go through the panel? and if so would 13 be accurate indication of power to the batteries? At the risk of being "picky," how the heck could we know how your boat is wired. Sure, they all come a "usual" way from the factory and most are wired with the alternator output to the switch, but a PO could have changed that. YOU need to trace the wires and find out yourself.Owners Manuals states 13v is a slow charge (such as for an automobile or power boat) and 13.5 to 14.5v is necessary for a sailboat. Local mechanic argues 13 is sufficient. Comments?Yes, see above, plus read the Ample Power Primer at www.amplepower.com or any other good reference on sailboat charging systems with new higher output alternators and smart three stage regulators, too long to write all of what the books have done here. Your local mechanic is wrong.Second Problem: Twice we have failed to turn the power switch to OFF before leaving the boat. Each time after 48 hours the batteries are near dead, although all circuits had been turned off at the control panel. Is the solution to test each circuit at control panel with a voltmeter to find out where the power leakage is? Yes. What makes you think the batteries are dead? Is your bilge pump stick on? Could be lots of things.Arthur, you have a really nice boat. I recommend that you do a lot of research on your own and consider buying Calder's Boatowner's Manual for Mech and Elec systems, the best $50 you can spend on your boat. Based on your questions, it appears that you need to learn a lot more about boat electrical systems. Nothing negative here, we've all been there, and have done that "homework." The questions you raise go to the basics of battery chemistry, charging and system maintenance, which is why people have written whole books about it, and too long to answer completely here. All I can suggest are some of the sources that have worked for me in the past. Calder's, Don Casey, lotsa stuff on the web, West Marine Advisors (online and in their catalogs), Ample Power, and any alternator regulator company like Balmar, Xantrex, etc. websites.The concepts aren't too difficult, but the specificity to YOUR particular boat is only something you can know.All the best,Stu
