Why not measure it? Here is a proposed method.....
I have been around sailing discussion fora long enough to know that this is one of the many sailing-related topics that does not appear to have a simple answer. IMHO, all indications are that it may well differ from vessel to vessel, from propeller to propeller and possibly as a function of boat speed and a number of other factors.So, why not simply measure it for your own vessel?The most obvious method, namely changing over from locked to freewheeling while underway is more complicated than it looks because the effect is likely to be minor and boat speed is constantly changing (although a well-dampened log or GPS may not always show that).So, here is the test I propose:On a calm day, just anchor in a tidal estuary, e.g. the Chesapeake Bay, and measure the speed of the tidal current with a log (your GPS won't work under these conditions, of course). As soon as the current registers approx. 1 knot you should switch from locked to freewheeling while measuring the change in pull on the anchor chain. Then repeat that at 2 and at 3 knots (or possibly more if your tidal flow permits).How do you measure anchor pull? Either with an oversized spring balance or calibrated strain gauge or with a simple heavy elastic snubber attaching your anchor chain to the bow (make sure the spring or the elastic snubber are stretched approximately halfway their maximum extension). To read the extension of the rubber snubber you will need a reliable, finely graded ruler as a yardstick. (also, you would need to calibrate this crude but effective weighing device later with some known weights in order to get quantitative results).If anyone goes to the trouble of actually measuring this we will finally have some real data to talk about rather than just so much hot air, prejudices and parroted opinions.Have fun!Flying Dutchmanhave fun
