Went out to my oday 26 this afternoon to bleed the fuel system and run the engine prior to splashing.
The procedure I used last season was: pump the bulb until fuel goes from the tank to the bleed valve at the high pressure filter, then actuate the lift pump manually, until fuel comes out the bleed screw at the high pressure pump.
Today, I Pumped the bulb style hand pump, and yet, was unable to draw any fuel out of the tank to the primary filter on the side of the tank. I suspected the bulb pump had failed. I could hear fuel agitating in the tank when I squeezed, I just couldn't move any fuel.
I replaced the bulb and was able to get fuel into the primary fuel filter and out the bleed screw of the high pressure filter. However I wasn't able to get fuel out the high pressure pump bleed screw using the lift pump. I bled to this point using the squeeze bulb.
I started the engine anyway. It started very hard, it took 3 or 4 attempts. It did start. I ran it 10 minutes. It archived full rpm.
I suspect my lift pump is broken. I'll probably encounter hard starting the next time I start.
What do you think about this. Will an engine start and run to full rpm without a lift pump?
Thanks
Joe
Thanks
Joe
