1996 461 cutlass bearing
bp461
Nov 28, 2010
1
beneteau 461 Groton,ct
Hello,
Has anyone ever changed the cutlass bearing on a 461 without dropping the rudder and pulling the shaft ? In other words can it be pushed out from the inside ?
Also, does anyone have the dimensions for a replacement bearing ? (and an online supplier ?)
Thanks in advance.
Bill
Nov 23, 2009
437
Beneteau Oceanis 361 Clipper --
On my Ben361 to change the cutlass bearing you simply need to remove the propeller and then find a way to pull it (usually it's not hard; these things are not stuck, just make sure you remove the two screws holding it). There's no need to remove the shaft or drop the rudder. I believe the same applies for the Ben461.
larryw
Jun 9, 2004
395
Beneteau OC400 Long Beach, CA
On my Bene, you just remove the prop, remove two set screws and the "cutlass bearing", a plastic sleeve, slides off the end of the shaft.
