just purchased a 95 Hunter 29.5 and learned that the tach is not accurate. PO said had very confusing instructions about some ratio? I will be going to the boat in two week and curious if someone else has come across this issue. I'm hoping it's a loose connection or a bad cable. Any other suggestions as what the issue may be?
Thank you in advance for any advice
