Novice question*1..Does the boom vang attach from the mast base plate to the same point on boom as the mast sheet?
#2 question...In reefing according to the way I understand owner manual.
A.....Reduce main sail halyard to hook the cringle on main sail reef near gooseneck/mast.
B....I believe there are two cringles on the main. We use one cringle on hook/rams horn.
The question is where does the line for reefing using second cringle come from.....?
Is it tied with a fig eigth knot ,to the samll bail that slides on bottom of boom?
Then through the second cringle and then through the boom sheves ,to the cam inside the forward end of boom to anchor/cleat using cam located there?
Then do I need to put a line for tieing up the sail carryover from reefing?
Please advise..mark txs much
